1. AC Question's Avatar
    For some reason my sd stopped working in my i have tried to get it to work but it keeps saying the sd card is blank or has unsupported filesystem and the only option i can find is to format my sd card but i have over 2thousand pics is there anything that i can do to fix my sd card or just hook it up to a pc
    09-16-2015 06:00 AM
  2. nahoku's Avatar
    Highly recommend you hook it up to a PC, and if the card is readable, copy all the files to the PC. If the card is becoming corrupt, which may be the case, you better try to transfer your data soon.
    09-16-2015 07:18 AM
  1. Debating whether to make the switch or not
    By qbngator in forum Google Nexus 6
    Last Post: 09-27-2015, 06:54 PM
  2. Cracked screen help Samsung S5, can I just change the glass?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 09-16-2015, 11:05 PM
  3. Replies: 0
    Last Post: 09-16-2015, 05:48 AM
  4. Is the HTC One M8 dual voltage???
    By cathesys in forum Ask a Question
    Last Post: 09-16-2015, 05:43 AM
  5. Replies: 0
    Last Post: 09-16-2015, 04:45 AM
