Why won't my g4 turn on?
kurchak31
4
I've only had the phone a couple months. It died last night due to normal low battery and now will not turn on at all. I have 3 spare batteries all of which don't work. I left it to charge over night with one of them and that didn't work either.
It rained quite a bit earlier in the day yesterday and my phone got a bit wet but the water damage sticker shows no signs of damage.
I've tried wiping the connectors, I'm not sure if I am doing it properly but it hasn't helped either.
Edit: At times the phone gets warm, even hot, so there is definitely some kind of response but still no power.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,582
4,725
113
What happens if you press and hold the Power button for at at least 10-15 seconds? If it still doesn't power on, then it's still possible that some moisture got into the phone, separately from the battery compartment. Any cracks in the glass or body?
If there's no visible sign of damage, it's worth contacting LG for warranty repair or replacement.
