I got a Note 4 last week, I am looking of the best printer app for my device so I can print from the Note. I have 2 HP printers at home, 1 is an OfficeJet, the other is an Envy. Please advise your thoughts, thank you.
Are those printers WiFi enabled?
I will give it a look, thank you.I found that 'PrinterShare' worked pretty good for me. However it costs money. Try the free version first to see if it works for you.
