Move to SD
Hi,
1)I am getting seriously annoyed with andriod and developers because the OS now makes the internal memory show up as an SD
2) you cant move all apps to SD my device has a low amount of internal memory so i use an SD card and would prefer most of my apps on the SD but developers dont actually always tick the move to SD option even when there is no need to actually have it on internal storage such as sky go etc.
so my question is; is there a way to move everything to SD including apps that have a grayed out option for the move to SD i feal we should have a option to move EVERYTHING exept core apps to SD
Hi,
