1. AC Question's Avatar
    I am trying to change the storage location in moto e but i can't,and also about the back upped messages..... plz can u help me in this anyone........
    09-20-2015 01:45 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! If you can't find an option in the System Settings to set the SD card as default storage, then it's not possible on that phone. This option isn't available on all Android devices. You can go check the settings of individual apps to see if they have their own options to save to SD by default (like, for example, the Camera app).
    Are you talking about backed up SMS messages? How did you back them up?
    09-20-2015 03:38 AM
  1. Overlapping apps / How do you keep your Note 5 running smooth?
    By Ash Mathew in forum Samsung Galaxy Note 5
    Last Post: 09-20-2015, 04:37 PM
  2. How can I select a sim, one for for internet use only, not for call or sms?
    Last Post: 09-20-2015, 04:01 AM
  3. when i tried to do anything it says
    Last Post: 09-20-2015, 03:52 AM
  4. i want to my prefetence to cellular instead of wi fi. how
    Last Post: 09-20-2015, 03:51 AM
  5. Replies: 1
    Last Post: 09-20-2015, 03:50 AM
