How To Find App That Is Using Mobile Data On Wifi
music_man185
411
Over the past couple days, I've noticed that even when connected to wifi, my 4g is lit up. I haven't installed any new apps, but I have had several updates to older apps. I've also looked at the running apps, but can't find anything suspicious. When I restart my phone, it goes away. How can I find which app is using mobile data?
Verizon Note 3
Murali14
10
I understand the issue. Before trying any app. Do check the option in the settings of apps that states "use only wifi or use only mobile data" option is enabled.
BTW, u can use Opera max to dis/enable mobile data/wifi for each application i the "App Management" section.
knowledge is power
