How can I redownload 4.2 on my quad core Android tv box?
A
AC Question
quad core android tv box download
i bought a quad core android 4.2 tv box from china and now all it does is load up with android robot and doesn't do anything else. where can I redownload android 4.2 to reinstall on the box.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,519
4,660
113
Re: quad core android tv box download
Welcome to Android Central! These off-brand and no-name Android TV boxes are notorious for having defective hardware or firmware, as well as having minimal to zero support. It's unlikely you'll find any help on this. Can you contact the manufacturer? It might help if you speak Chinese.:-\
Markizta
