1. AC Question's Avatar
    I try charging my phone, but the charger or the charging port wont work
    09-27-2015 07:41 AM
  2. the tall guy's Avatar
    Hi, does the charger work on another phone, if not then you might need to buy a new charger. If it does work on another phone then the issue will be with the phone. Can you replace the battery on the phone?
    09-27-2015 07:51 AM
  1. Poll: What is your ideal phone size
    By lukazi in forum Samsung Galaxy S6
    Last Post: 09-28-2015, 05:49 AM
  2. Why am I getting the error :T15 I00 F00 S00 N00 V00?
    Last Post: 09-27-2015, 10:09 AM
  3. What is this icon in my notification bar
    Last Post: 09-27-2015, 10:06 AM
  4. My screen went off when the brightness is auto
    By Rohith in forum Ask a Question
    Last Post: 09-27-2015, 10:00 AM
  5. I cant change my dial pad themes as per htc one m8 themes app
    Last Post: 09-27-2015, 08:19 AM
