The way your post reads it sounds as though it should be displaying an ad when charging but I'm assuming it should not be doing this behavior. What is the ad for? You can be be general if you'd like, an app, a service, a web page... And if you swipe right what does it ask for? It's interesting that it only happens while charging. Does it matter what charger you use or if you charge from USB thru a pc or wall outlet?
It truly sounds app oriented, being that you recently did a FR, it probably wouldn't hurt you too much to do it again. That way you can plug it in fresh from a reset and see if the issue exists? Or since you say not much has been installed begin uninstalling items and testing after a restart if the issue goes away.
09-28-2015 07:44 PM
