1. AC Question's Avatar
    I have my phone set to ring & vibrate on calls & used to work fine but the last few days it only vibrates & no audible sound. I checked & call volume is on & turned up all the way but still now ringer when receiving a call. What else can I check or do?
    10-03-2015 12:29 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which phone? Go to Settings>Sound & Notifications, and check the volumes there. Look for the Ringtones volume, not the Call volume. Also, go to where you select ringtones, and try picking a few different ones--does the phone play a sample of each tone?
    10-03-2015 10:05 PM
  3. Edward Podmokly's Avatar
    I have the same problem on my Nexus 5 it does not ring for calls and text messages have to restart the phone then it's fine for a while then does it again all settings are good
    01-18-2016 11:50 AM
  1. Replies: 1
    Last Post: 10-03-2015, 10:13 PM
  2. Note Pro 12.2 wont turn on, not rooted
    Last Post: 10-03-2015, 10:12 PM
  3. Replies: 2
    Last Post: 10-03-2015, 01:57 PM
  4. My contacts are gone after update!
    Last Post: 10-03-2015, 12:56 PM
  5. Replies: 0
    Last Post: 10-03-2015, 12:22 PM
