1. AC Question's Avatar
    Ok my phone has been draining really fast the last couple days but now it wont stay on at all wont out the charger but even with the charger it wont even go past the battery symbol that's 100% Help
    10-05-2015 04:55 PM
  2. belodion's Avatar
    A failing battery perhaps?
    10-05-2015 05:12 PM
  3. Rukbat's Avatar
    Or an app gone crazy. Check the battery (Settings/General/Battery) to see if anything is using a lot of battery that shouldn't be.
    10-05-2015 05:23 PM
  1. Which model of phone should I buy?
    Last Post: 10-05-2015, 05:29 PM
  2. Replies: 2
    Last Post: 10-05-2015, 05:15 PM
  3. How can i get the LG ringtones back on my phone? I have an LG
    Last Post: 10-05-2015, 05:04 PM
  4. Replies: 0
    Last Post: 10-05-2015, 04:41 PM
