1. AC Question's Avatar
    trying to decide which one to buy.
    note 5 is fragile so nervous about that.
    iphone 6 plus is also fragile but is simple. although note 5 seems like more bang for the buck. please let me know thought on this. thanks.
    never owned an android before
    10-05-2015 05:42 PM
  2. Miller6386's Avatar
    As much as we'd like to we can't tell you what phone you'd like/use more.....
    My Note 4 is the best phone I've had in years and I can't see myself getting rid of it
    Note 4tified
    10-05-2015 06:54 PM
  3. Rukbat's Avatar
    It's a personal choice. Personally I wouldn't keep either one if I got it for free - no external SD card and a non-replaceable battery are deal breakers for me.
    10-06-2015 02:16 AM
  1. T-Mobile Samsung Note 5 32Gb Pearl White
    By nicky_willz in forum Marketplace Archive
    Last Post: 11-30-2015, 11:40 AM
  2. won't send pictures or insert images in my txt.
    Last Post: 10-05-2015, 05:37 PM
  3. Is there a root for a ZTE Grand Max Plus?
    Last Post: 10-05-2015, 05:22 PM
  4. Did Samsung remove finger Air View for the Note 5?
    By Roundpotato in forum Samsung Galaxy Note 5
  5. Should my 6 edge plus edue plus be burning
    By hhibbert19@gmail.com in forum Ask a Question
    Last Post: 10-05-2015, 04:38 PM
