1. okiebirdnerd's Avatar
    I have the Note 4 and here's what I di to fix the freezing. I went into Settings then Applications then Application manager then to downloaded apps, then scroll to Google App, select "uninstall updates" THEN go to the Playstore App, in PlayStore select 'menu' on the left, then settings, then set "do not auto update" This will keep your phone from updating the google app.
    Note* When I did the above I lost the mic on the keyboard so I rebooted my phone. Now my Google Voice to Text window is black instead of white.
    I confirmed that this works by doing the following and could not replicate it-
    Here's how to replicate this issue:
    1- say some words with voice to text and send.
    2- TAP POWER BUTTON TO PUT DEVICE IN SLEEP MODE AND TURNS DISPLAY OFF.
    3. PRESS POWER BUTTON TO BRING BACK DISPLAY.
    4. Google Voice is now stuck and cannot be dismissed.
    WillRXR likes this.
    10-05-2015 10:39 PM
  2. B. Diddy's Avatar
    Welcome back, and thank you for that contribution! I know you posted the same thing in that large thread, but for other people's reference, I will give the link here: http://forums.androidcentral.com/ask...ing-up-me.html
    10-06-2015 12:05 AM
  3. gurisingh's Avatar
    Thanks ! I've had the same problem and it's fixed now.
    10-06-2015 03:34 AM
  1. Where/When to buy z5?
    By dkny2kx in forum Sony Xperia Z5 & Z5 Compact
    Last Post: 02-14-2016, 08:12 PM
  2. Video playback freeze issue
    Last Post: 10-06-2015, 12:13 AM
  3. Replies: 1
    Last Post: 10-06-2015, 12:10 AM
  4. Replies: 1
    Last Post: 10-05-2015, 10:58 PM
  5. Will Kies backup save gmail Settings on Samsung Note
    Last Post: 10-05-2015, 10:03 PM
