1. lDaChOsEnOnEl's Avatar
    So I was with verizon up until a few weeks ago, now im with sprint. All my contacts from my old phone we backed up with verizon wireless back up assistant, So im trying to figure out if there is a way I can save my contacts to transfer them to my new Evo before I cant login into my verizon account any more?
    02-08-2011 09:58 PM
  2. RHChan84's Avatar
    If you have a gmail account, then all your number should of been backed up to your gmail and once you go to a new device, all your contacts would of transferred over. But Sprint should be able to transfer the contact over.
    Another option is MyBackUp Pro.
    02-08-2011 11:00 PM
  3. takeshi's Avatar
    As Rchan84 says, if you had contacts synced from your account on your Droid X then there's no need to use the Verizon Backup Assistant. I'd actually suggest avoiding the use of it unless you're migrating from a feature or "regular" phone to a smartphone.
    02-09-2011 11:09 AM
