1. Nick Ericson's Avatar
    I was using my phone normally and suddenly, i saw a scratch on it. The scratch is very fine and thin but then it somehows reflect the light from individual pixels. The light looks like ones you get when use your phone with greasy hands and the screen has tiny blue, green and red dots.
    10-07-2015 11:07 AM
  2. belodion's Avatar
    Welcome to Android Central.
    A screen protector may fill in the scratch, or subdue it, if the refractive indices of the adhesive layer and the plastic or glass of the protector are anything like similar to that of the screen glass. Any subsequent scratch on the protector will show the same effect that you refer to, but a protector is easily enough replaced should that happen.
    10-07-2015 12:15 PM
  1. How do I fix the front of phone camera samsung galaxy s4
    Last Post: 10-09-2015, 02:58 AM
  2. How do I change a theme?
    By AC Question in forum Wallpapers, Ringtones, and Themes
    Last Post: 10-08-2015, 02:47 AM
  3. Why do I need to choose the SIM card to use when sending a text?
    By Shankbone in forum General Help and How To
    Last Post: 10-07-2015, 11:01 AM
  4. Books I have read on my hudl can I save on a memory stick?
    Last Post: 10-07-2015, 10:43 AM
  5. Can I get my AMazon apps on my Tablet?
    Last Post: 10-07-2015, 10:41 AM
