1. JKarhani's Avatar
    Need to disable the external SD card on tablet android 4.2, how?
    I don't want anyone who inserts any SD card to be able to copy files from my tablet to this external SD card ( I have 3 software preinstalled on the tablet thru which they can copy files) is there a way not to let SDCard1 be shown??
    Any way to do this??
    10-07-2015 09:50 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! After a little searching, I wasn't able to find an app that can do this. You could consider locking the file folders that you want to protect, using Folder Lock.
    10-07-2015 10:50 PM
  3. JKarhani's Avatar
    Folder Lock is not enough.. I want to prevent any external SD card to be readable or writable thru this tablet.. ANy other idea?
    10-07-2015 11:56 PM
  4. B. Diddy's Avatar
    Oh, I see. You had mentioned in your OP that you didn't want files copied from the tablet to SD, so I didn't think you were concerned about reading the SD. Maybe someone else will have a suggestion.
    10-08-2015 02:15 AM
  5. JKarhani's Avatar
    Thank you Diddy..hope someone could help with a solution even if with money..
    10-08-2015 01:14 PM
  1. Cannot keep Note 5 paired to my Cars Bluetooth
    By Scott Newell in forum Samsung Galaxy Note 5
    Last Post: 03-19-2016, 08:53 AM
  2. New guy on the block
    By lifeisablog in forum New to the Forums? Introduce Yourself Here!
    Last Post: 10-10-2015, 09:16 AM
  3. Why does my screen randomly turn off on Galaxy Camera 2?
    Last Post: 10-07-2015, 10:59 PM
  4. how to upgrade android version of galaxy grand gt I 9082
    By ajay singh18 in forum Ask a Question
    Last Post: 10-07-2015, 10:57 PM
