1. AC Question's Avatar
    is it possible to lock an audio file like songs that you transfer with a computer to a phone so that the phone cant transfer it through bluetooth to anybody just like ringtones that comes with a phone cant be sent but only be listened to
    10-11-2015 12:59 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! There are file locker apps out there, but I think you'd always have to unlock the file whenever you wanted to listen to it. This is an unusual request--are you concerned that someone might try to steal your music via Bluetooth? Or are you worried that a friend or family member might take your phone and copy music off of it?
    10-11-2015 01:44 AM
  1. Replies: 8
    Last Post: 04-07-2016, 12:25 AM
  2. Replies: 4
    Last Post: 10-11-2015, 07:53 PM
  3. From 4.4.2 KitKat to Lollipop?
    By ivanbin in forum Samsung Galaxy Note 3
    Last Post: 10-11-2015, 03:32 AM
  4. How do I stop a failed email from re-sending?
    Last Post: 10-11-2015, 12:57 AM
