1. AC Question's Avatar
    I am trying to use the phone insted of a sat nav but dont seem able to connect to a satalite. tried using several apps but noting seems to connect and phone simply states tsearchin GPS
    10-11-2015 04:42 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which phone? If you go to Settings>Location, is it set to High Accuracy or Device Only? Both of those settings mean the GPS radio is turned on, while Battery Saving means it's turned off (relying instead on wi-fi and cell signal for estimating location).
    10-11-2015 07:50 PM
  1. how much $$$ will it likely cost to replace a cracked glass back cover?
    By KiwiCoalBattery in forum Samsung Galaxy Note 5
    Last Post: 04-05-2017, 07:37 PM
  2. Mac or PC?
    By pseudoware in forum General News & Discussion
    Last Post: 03-22-2016, 01:54 PM
  3. Replies: 4
    Last Post: 10-11-2015, 02:22 AM
  4. Why does my phone not come on?
    Last Post: 10-11-2015, 01:30 AM
  5. Lg gps goofy
    By Zack2chat in forum Ask a Question
    Last Post: 10-10-2015, 11:57 PM
