Does anyone know what phones are compatible with the Sprint SIM card SIMGLW416R?
A
AC Question
The sim card part is SIMGLW416R. Under the ICC ID number is 53.07a
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,592
4,732
113
Welcome to Android Central! A Sprint SIM card can work in a CDMA phone that is compatible with the Sprint network. But the phone has to be registered on the Sprint network as well. Why do you ask? Did you find a Sprint SIM card somewhere, and want to use it? I wouldn't do that, because it's either an inactivated card, or it's someone else's (in which case you'd be stealing their phone and data plan).
akbarramadhani12
