1. DixieDutchess's Avatar
    My accounts got hacked & my ex has me as a client, Uses dnla to upload all my data to his PS3 & controls it
    10-12-2015 02:57 PM
  2. Rukbat's Avatar
    The easiest way is to note down (don't back up) all your apps (on paper), then reflash the ROM, set the phone up on a different Google account (make a new one) and install all your apps (directly from the Play Store).
    There are other, much more complex ways.
    10-12-2015 05:51 PM
  3. Crashdamage's Avatar
    So that you don't have to buy your apps over again, I think you can keep using the same account they are on. Just changing your passwords on all your accounts should do. Doesn't matter if he has your user names, if he doesn't have the passwords he can't get in the accounts.
    For good measure you might consider doing a factory reset on your phone. If you do, don't forget the backups! And as Rukbat suggested, install apps only from the Play store.
    10-12-2015 06:24 PM
  1. What do you think Verizon would do to keep a subscriber??
    By Mr.Gadget in forum General Carrier Discussion
    Last Post: 10-28-2015, 09:39 PM
  2. Replies: 2
    Last Post: 10-12-2015, 08:37 PM
  3. Why do Android upgrades expire?
    Last Post: 10-12-2015, 05:56 PM
  4. How can I lock the screen when playing a video?
    Last Post: 10-12-2015, 02:47 PM
  5. Replies: 0
    Last Post: 10-12-2015, 02:28 PM
