1. acsurfer's Avatar
    Some Android tablet says No SIM. No SIM card slot.
    Does it mean that the only way for that tablet is to use WIFI to connect to the internet?
    I am a noob so I am not too sure.
    I think there is no way to use a data SIM card.
    Thanks
    10-18-2015 08:02 AM
  2. STARGATE's Avatar
    Most of the tablets out there are WiFi only.
    So yes, if the tablet you're trying to get has no SIM card slot, that means you can only use it while on WiFi.
    10-18-2015 08:27 AM
  1. Replies: 4
    Last Post: 10-27-2015, 03:36 AM
  2. Replies: 1
    Last Post: 10-18-2015, 03:40 PM
  3. Replies: 0
    Last Post: 10-18-2015, 07:28 AM
  4. Fly Tablet-no system upgrade button-how to upgrade?
    Last Post: 10-18-2015, 07:18 AM
  5. Replies: 0
    Last Post: 10-18-2015, 06:46 AM
