1. AC Question's Avatar
    i have iball andi4.5,and i have a problem in my touch screen not responding on particular area.can any one help me.
    10-18-2015 11:48 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! That usually means that the digitizer is faulty in that area. You'd need to get the digitizer replaced at a repair shop, or contact the manufacturer if it's still under warranty.
    10-19-2015 01:37 AM
  1. Lock Screen Pin Code Problem
    By juwster in forum HTC One M8
    Last Post: 12-21-2015, 03:02 PM
  2. Help... Is screen protector required for Note 5?
    By grbrao in forum Samsung Galaxy Note 5
    Last Post: 10-20-2015, 07:23 PM
  3. galaxy s5 screen locks on call screen during calls
    By zspira in forum Ask a Question
    Last Post: 10-19-2015, 10:22 PM
  4. My HTC 510 desire is stuck on the HTC screen what do I do?
    Last Post: 10-19-2015, 02:16 AM
  5. Reset Screen Timeout and Secured Lock Time settings
    Last Post: 10-19-2015, 01:45 AM
