1. jensen91's Avatar
    I was doing a factory reset so I could give my galaxy s3 to my daughter. when I looked at it again I had to use volume buttons to select reboot, but it gets stuck on the 4g lte screen. I tried taking the battery out but it won't go past. Any help would be great.
    10-19-2015 01:41 PM
  1. Replies: 1
    Last Post: 12-18-2015, 05:20 AM
  2. How can I get lollipop update for my Archos 50b Helium?
    By El Gatto in forum Ask a Question
    Last Post: 12-18-2015, 05:18 AM
  3. Why can't I find an app that says it is installed?
    By AC Question in forum Android Apps
    Last Post: 10-19-2015, 01:48 PM
  4. What is the model number for the DROID MAXX?
    By stanleywinthrop in forum Motorola Droid MAXX
    Last Post: 10-19-2015, 01:36 PM
