UK's choice :/
Looking to buy a new phone soon,however, I live in UK so I don't really have many options of mid-range phones, was looking at nexus 5x 16gb but no micro sd slot...
So, which phone should I buy? ~£300
And please, 5.2" is the max.
Thank you,looking forward for any of your choices)
Re: UK's choice :/
Hello and welcome to the forums!
What about the Moto X Play? The screen is 5.5" but the external dimensions are practically the same than the Nexus 5X.
Re: UK's choice :/
definitely a great choice but not sure how ergonomic it would be in 1 hand, I just need it for everyday use at Uni, not playing many games, usually just web surfing and using main camera a lot
Re: UK's choice :/
Don't worry about that :) It feels great in the hand and much lighter than expected. I use mine one handed without problems. Also you should consider other mid-range phones like the Moto G 2015 or the Alcatel Idol 3 4.7"
Re: UK's choice :/
to be honest, Moto G just looks cheap
