1. AC Question's Avatar
    The sound on my S4 randomly stops working. both speakers.
    The phone gets all glitchy, videos randomly play in fast or slow motion. And if I get a call they can hear me just fine but I can't hear as both speakers aren't working. It is remedied by restarting the phone but will happen again in a few hours or even sometimes a few minutes. I have factory reset my phone and cleared the cache. samsung says it is time for a service. do I have any options since my phone is over a year old. When I was with apple they were really good about just replacing phones,is there any options like that with samsung?
    10-26-2015 04:46 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! If you have an SD card, try using a different one, in case that card is corrupt and causing issues. The problem might also be due to a 3rd party app, which can be difficult to pinpoint. Sometimes you just have to uninstall apps one by one until the behavior stops. Or do a factory reset, and reinstall apps one by one.
    10-26-2015 05:37 PM
  1. Recommended phone for Tmobile
    By arukaen in forum General Carrier Discussion
    Last Post: 10-28-2015, 09:57 PM
  2. Why is my phone rebooting while installing (or updating) apps?
    Last Post: 10-27-2015, 05:21 PM
  3. Why does my Note 3 have a echo only I can hear?
    Last Post: 10-26-2015, 08:38 PM
  4. How do I sync my Galaxy S6 with my Outlook calendar?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 10-26-2015, 06:30 PM
  5. How do I make notifications show up on my lock screen?
    Last Post: 10-26-2015, 05:41 PM
