1. AC Question's Avatar
    My phone just died as it displayed the low battery mode warning, I'm not sure what percentage it had. So I put it on charge and it got up to 10% before I turned it on. Then when I turned it on it had 55% battery life?? I took it off charge and I've been using it for about 20 minutes and the battery has only gone down by 3%. It's impossible to go from dead to 55% in less than 10 minutes and I can't just have my phone dying on me when it fells like it.
    10-28-2015 04:02 PM
  2. sethyboy's Avatar
    It could be that your battery is going bad in some way. What device is this, exactly?
    10-28-2015 04:12 PM
  1. My Note 5 doesn't have a Mobile Data quick button
    By amyf27 in forum Samsung Galaxy Note 5
    Last Post: 10-28-2015, 10:55 PM
  2. Can I use my Note 3 without a carrier?
    By AC Question in forum Samsung Galaxy Note 3
    Last Post: 10-28-2015, 04:37 PM
  3. Does the AT&T S5 5.1.1 Update turn on WiFi calling?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 10-28-2015, 03:33 PM
