Re: Blocking phone numbers
I have added them all to a single contact called "Block" (name it whatever you want, really). Then in the edit contact screen, bring up the menu (3 dots in the top right corner) and select to send all calls to voicemail. The phone will now auto-reject calls from those numbers and send them to voicemail.
