1. flanc28906's Avatar
    I have a Moto 3G. How do I block phone numbers that are spam? Thanks
    10-30-2015 03:04 PM
  2. hallux's Avatar
    I have added them all to a single contact called "Block" (name it whatever you want, really). Then in the edit contact screen, bring up the menu (3 dots in the top right corner) and select to send all calls to voicemail. The phone will now auto-reject calls from those numbers and send them to voicemail.
    10-30-2015 03:25 PM
  1. Blue light blinks and turns my phone on?
    By Lucas Chadwick in forum Samsung Galaxy Note 4
    Last Post: 11-01-2015, 02:14 AM
  2. How can I connect my Android phone to my hearing aids?
    Last Post: 10-30-2015, 02:24 PM
  3. Replies: 0
    Last Post: 10-30-2015, 02:08 PM
  4. How to you delete an incoming number?
    Last Post: 10-30-2015, 01:58 PM
  5. Black Number Pad in Foreground, how can I get rid of it?
    By JoeDeRose in forum Samsung Galaxy Note 5
    Last Post: 10-30-2015, 12:41 PM
