1. AC Question's Avatar
    The speakers in nextbook tablet don't work but get audio when Bluetooth speakers are paired.
    10-31-2015 02:23 AM
  2. randry1's Avatar
    I am having the same problem with the exact device. I am getting a message to check my media audio settings because they might conflict with headset that is trying to be plugged in. I am not trying to plug in headset. I had to install SoundAbout App to have control over speaker and headset. I am glad to hear that I am not the only one having this problem. Maybe Nextbook or will come up with a fix or update to cure this problem and others with this tablet. I have had contant problems with the NXA101LTE116 since I bought it several months ago. I don't think it was ready for prime time and the website still has no support or in depth user instructions that are any help. I'm about ready to throw in the towel on this one and purchase a better known brand.
    01-08-2016 06:22 PM
  1. Replies: 2
    Last Post: 10-31-2015, 10:28 AM
  2. Navigation home button doesn't work
    Last Post: 10-31-2015, 08:38 AM
  3. Need help on my POLAROÏD Pro5023 PW
    By Hanzo Inuya in forum General Help and How To
    Last Post: 10-31-2015, 02:20 AM
  4. Why won't my Samsung Galaxy Exhibit go to main screen?
    By AC Question in forum T-Mobile Samsung Exhibit 2 4G
    Last Post: 10-31-2015, 02:16 AM
  5. Ear speaker specs
    By Tonyduzsumyayo in forum Ask a Question
    Last Post: 10-31-2015, 01:37 AM
