1. Mohamad Habba's Avatar
    Hi,
    I have galaxy note 3 SM-N900, my android version 4.4.2.
    Every time I try to update my mobile using software update from setting>General>about device>Software update>update.
    I receive message “the latest updates have already been installed”.
    I need to update it to lollipop.
    Developer mode was on, I reset my mobile to factory setting, and now it is off, but mobile still not updating.
    11-03-2015 12:15 AM
  2. Rukbat's Avatar
    Your carrier has to send out the update. If they aren't sending out 4.4.4 or Lollipop, you're not going to get it from them. You can probably find update files for that model Note 3 at XDA Forums.
    11-03-2015 12:34 AM
  3. Mohamad Habba's Avatar
    All my friends received all new updates using same carrier, even using home or work WIFI I receive same message.
    11-03-2015 01:57 AM
  4. Mohamad Habba's Avatar
    Any one know?
    11-04-2015 12:37 PM
  1. Is it worth getting a Note 5 now?
    By JHop86 in forum Samsung Galaxy Note 5
    Last Post: 12-01-2015, 03:59 AM
  2. Not receiving Gmail notification
    By Sabrina Fair in forum Samsung Galaxy Tab S2
    Last Post: 11-15-2015, 01:58 PM
  3. Battery life after update?
    By gottria in forum Samsung Galaxy Note 5
    Last Post: 11-05-2015, 01:49 PM
  4. Why can't I receive the Lollipop update on my AT&T unlocked LG G3?
    By AC Question in forum Android 5.0 Lollipop
    Last Post: 11-05-2015, 06:05 AM
  5. Replies: 0
    Last Post: 11-03-2015, 12:15 AM
