How do I reprogram an Android phone using a laptop or pc?
  • Start date Start date
A
AC Question
How to reprogram an android phone using laptop or pc?
Please kindly give me some information or details on how to reprogram an android phone. Please give me a website or software that can help me to reprogram my android phone.
Re: How to reprogram an android phone using laptop or pc?
Reprogram it in what way? If you want to set it up on your carrier account, it could be as simple as swapping in the SIM card for your account. If you want to change the way the device works by rooting it, you need to provide more information as the process is different for different devices. Not to mention, there's still only so much you can do on your own.
how to reprogram my cloudfone icelite
my phone has have a virus.my internal storage is going out of storage.
i always reset data..my phone.but nothing happen..my internal storage is 90 plus mb..but now it almost 20 to 30 mb internal.. i didnt downloaded any kind of apps.
i need your help.
Re: How do I reprogram my cherry mobile amber 2
how to remove monkey virus on my cherry mobile amber 2 ? do reprograming can fix it?
Welcome to Android Central! Your question is not related to the original post of this thread. Please create a new thread for your question, which will give you a better chance of receiving a relevant answer. Thanks!
Re: how to reprogram my cloudfone icelite
I've the same issue but at the end I paid 500 pesos for reprogramming. But if u want, u can download the stockrom/firmware for your device and flash it using smart flash tool or if your phone is rooted you can use twrp or cwm to flash rom/custom rom...
Techman
