my former employer required a PIN or password to use the encrypted devise memory. As i was trying to change that password and tried a restart - neither the old password or the new screenlock password i had set is working. help!!
Printable View
Welcome to Android Central! Is this your own phone that you had to encrypt for your former employer? Or is it a company phone?
When you changed the password, it should have asked you to enter it twice, correct? Is it possible you made a typo twice while you were setting the password?
