1. AC Question's Avatar
    my former employer required a PIN or password to use the encrypted devise memory. As i was trying to change that password and tried a restart - neither the old password or the new screenlock password i had set is working. help!!
    11-08-2015 10:15 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Is this your own phone that you had to encrypt for your former employer? Or is it a company phone?
    When you changed the password, it should have asked you to enter it twice, correct? Is it possible you made a typo twice while you were setting the password?
    11-08-2015 04:36 PM
  1. Replies: 7
    Last Post: 11-11-2015, 01:01 PM
  2. How can I fix a back-up Pin?
    Last Post: 11-08-2015, 04:40 PM
  3. Why is Moves Activity App not compatible with my new Samsung S6?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 11-08-2015, 04:39 PM
  4. Replies: 1
    Last Post: 11-08-2015, 11:53 AM
  5. Replies: 1
    Last Post: 11-08-2015, 11:52 AM
