Hello,
On my Note 5 after I download a PDF from an email attachment, I then rename it to something I can remeber and then create a shortcut to the file on my home screen. After that I will then edit the PDF with PDF write software. Problem is that I can not upload the edited file to Gmail or anything else, because I can't find it. I can see it on my home screen, but when I go to "attach a file" in gmail or any other program, I can not find the edited PDF, I can find the orginal tho. Any ideas?
Thanks
11-09-2015 07:47 PM
