1. AC Question's Avatar
    i just got a custom os to put my galaxy y from 2.3.6 and i kinda screwed up and i cant even get my phone past the load up screen also ive tried backing up my files before and restore through odin but it keeps on failing. PLZ help
    11-10-2015 10:26 AM
  2. Rukbat's Avatar
    Find the stock ROM at SamMobile Firmwares, then follow our guide at [Samsung] How to flash Stock ROM via ODIN.
    (Flashing a ROM is kind of boring, and it'll take from 5 to 10 minutes to restart the first time, so make sure you have something to do, or you'll be staring at the phone for at least 5 minutes having a heart attack, wondering if you broke your phone.)
    Laura Knotek and aximtreo like this.
    11-11-2015 12:46 AM
  1. How do I switch out of folder view in Samsung Knox?
    By ellenb76 in forum Samsung Galaxy S5
    Last Post: 11-12-2015, 06:27 AM
  2. No notifications when phone is on vibrate?
    By sdardoin in forum ASUS ZenWatch 2
    Last Post: 11-11-2015, 09:28 AM
  3. Replies: 1
    Last Post: 11-11-2015, 12:50 AM
  4. Why does my "Facebook" app uninstall with phone reboot?
    By AC Question in forum Android Apps
    Last Post: 11-10-2015, 10:21 AM
  5. I have a white on white cursor, how can I fix it?
    By AC Question in forum Samsung Galaxy Tab4 7.0
