How do I remove the passcode without deleteing data?
  • Start date Start date
A
AC Question
How to remove passcode without deleteing data
I dont know my google account and i dont want to do a factory reset how can i save my information and get the passcode off my phone
Re: How to remove passcode without deleteing data
You need one of those to get into the phone. Even if you wipe it will still ask for the Google account the was on the device before hand. Is this your device?
If so I would contact Google to reset your information. Good luck.
kankuraon
