1. AC Question's Avatar
    i have downloaded the sdk stand-alone package and tried too unlock boot loader but my phone wont get to fastboot mode.
    first i type the command: "adb reboot bootloader" , and then my phone turns off immediately but then nothing...... the screen stays black and even if i tried it manually it doesn't work, my phone keeps going on and off if i hold power+volume-up. if i try any other combination it goes in recovery mode.
    ok and after i execute the adb command i put: "fastboot oem unlock" and then i get this "..." like forever. if i remove the phone it gives me an error!
    here the command prompt log:
    Microsoft Windows [Version 10.0.10240]
    (c) 2015 Microsoft Corporation. All rights reserved.
    C:\WINDOWS\system32>fastboot oem unlock
    < waiting for device >
    ^C
    ^C
    C:\WINDOWS\system32>adb reboot bootloader
    * daemon not running. starting it now on port 5037 *
    * daemon started successfully *
    error: device '(null)' not found
    /*from here i plugged my phone in and usb debugging enabled*/
    /*it truns off and stays with a turned off screen*/
    /*i check to see if phone is connected*/
    C:\WINDOWS\system32>fastboot devices
    mt6582_phone fastboot
    /*this is where it gets stuck*/
    /*then i unplug my phone and get this*/
    FAILED (status read failed (Too many links))
    finished. total time: 103.600s
    /*the rest is just me trying to figure it out */
    ^C
    ^C
    11-14-2015 03:11 PM
  2. Golfdriver97's Avatar
    It might be a signed driver issue. What device is this for?
    Laura Knotek likes this.
    11-14-2015 03:45 PM
  1. How can I save videos?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 11-17-2015, 02:32 PM
  2. I was able to bend my 6p flat again....
    By mvasquez009 in forum Nexus 6P
    Last Post: 11-15-2015, 06:56 PM
  3. Upgrading to M worth it if rooted?
    By quietlybrilliant in forum Google Nexus 6
    Last Post: 11-14-2015, 06:10 PM
  4. Why can't I update my J1 duos?
    Last Post: 11-14-2015, 03:04 PM
  5. Replies: 0
    Last Post: 11-14-2015, 03:03 PM
