1. AC Question's Avatar
    when i plug it in nothing shows its charging, i went to other retailers that had the phone for sale but nobody could diagnose its problem though time and time i explain its the battery port that is pushed up so the charger cannot connect whatsoever
    11-18-2015 11:24 PM
  2. belodion's Avatar
    If you mean that the connector inside the port has been pushed up, it will need repair. If it is the result of faulty manufacture, the warranty ought to cover it....contact the manufacturer's support for advice.
    Laura Knotek likes this.
    11-19-2015 12:24 AM
  1. i forgot my private mode password. Is my stuff lost for good?
    Last Post: 11-25-2015, 02:56 AM
  2. Replies: 1
    Last Post: 11-19-2015, 12:29 AM
  3. Replies: 0
    Last Post: 11-18-2015, 11:22 PM
  4. How to pin an app on Android 4 tablet
    By usafguy99 in forum General Help and How To
    Last Post: 11-18-2015, 11:12 PM
  5. Mr. Time widget not loading on watch
    By Ittlebit in forum Samsung Gear S2
    Last Post: 11-18-2015, 11:07 PM
