I dropped my tablet in the water?
A
AC Question
A couple of weeks ago I dropped my tablet in the sink for 5 seconds and the water reached 2 inches from the bottom. I shook the rest of the water out and continued to use it. After a few minutes it kept restarting and I turned it of completely. Then I did something really stupid and charged it. The next day I was using it and it kept saying it was charging even though the plug was not connected. When I turned it of completely It was still doing it and was draining all my battery because it kept turning on. It went away after a couple of days. Since then, my tablet has been working fine but Now It is doing it again. And I think the battery became fat.
Does anyone know how to fix this? If so, what should I do? Should I get someons to fix it?
I use my tablet at school a lot but I don't want it going low battery.
