1. AC Question's Avatar
    A couple of weeks ago I dropped my tablet in the sink for 5 seconds and the water reached 2 inches from the bottom. I shook the rest of the water out and continued to use it. After a few minutes it kept restarting and I turned it of completely. Then I did something really stupid and charged it. The next day I was using it and it kept saying it was charging even though the plug was not connected. When I turned it of completely It was still doing it and was draining all my battery because it kept turning on. It went away after a couple of days. Since then, my tablet has been working fine but Now It is doing it again. And I think the battery became fat.
    Does anyone know how to fix this? If so, what should I do? Should I get someons to fix it?
    I use my tablet at school a lot but I don't want it going low battery.
    11-22-2015 09:16 PM
  2. Almeuit's Avatar
    I would take it to a local repair shop to fix the issue.
    11-24-2015 01:52 PM
  1. So ive had the edge plus for maybe a week now need some advice :)
    By Studio Ghibli in forum Samsung Galaxy S6 edge+
    Last Post: 11-25-2015, 01:18 AM
  2. Stuck in the rebooting cycle
    By aog3 in forum Samsung Galaxy Tab S 10.5
    Last Post: 11-23-2015, 12:13 AM
  3. Why can't I use my keyboard on my phone?
    Last Post: 11-22-2015, 09:11 PM
  4. Replies: 0
    Last Post: 11-22-2015, 08:49 PM
