Can it be streamed to a blu ray player?
A
AC Question
can it be streamed to a blu ray player
can all access stream to a Samsung 6500
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
Streaming is to the internet, so if your 6500 can connect to the internet (by itself, through your router), yes. Otherwise, no - BluRay players can't be sent video, except from BluRay disks that are put into them. You should be able to stream from your phone to your TV, though - use a Chromecast device.
jokomad
