1. AC Question's Avatar
    I think Android assistant app accidentally deleted important file then i cant find android setting so i tried factory setting but after that i still cant find android setting on home when i tried clicking the one on slides it just says launcher 3 has stop working now i cant set up my wifi or use anything HELP
    11-24-2015 10:25 PM
  2. the tall guy's Avatar
    Try uninstalling action launcher 3 - this should bring you back to your stock launcher. Once you've tried that let us know if you still need help.
    11-25-2015 02:32 AM
  1. Replies: 3
    Last Post: 11-26-2015, 02:19 AM
  2. Replies: 2
    Last Post: 11-25-2015, 12:19 AM
  3. Why did my ringer and msg alert just stop working?
    Last Post: 11-24-2015, 10:13 PM
  4. Software updates first on Android one
    By jaleelhamid in forum Ask a Question
    Last Post: 11-24-2015, 09:34 PM
  5. How stop Notifications while streaming movies??
    By mawil1013 in forum Android 5.0 Lollipop
    Last Post: 11-24-2015, 09:00 PM
