1. AC Question's Avatar
    factory reset did not re stall SMS nor Internet....seems Com.phone. is missing
    11-24-2015 11:08 PM
  2. srkmagnus's Avatar
    That shouldn't be missing unless you deleted the files via root. Have you checked APN settings and/or the SIM card to make sure everything is set properly?
    11-24-2015 11:40 PM
  3. Rukbat's Avatar
    If system files are missing, you're going to have to reflash the ROM. (Back up all the files you don't want to lose first - see Backing up an Android Device.)
    11-25-2015 01:59 AM
  1. A way to disable LTE?
    By adamdadam in forum LG Watch Urbane 2nd Edition
    Last Post: 11-25-2015, 11:35 AM
  2. Facebook still notifies even with Do Not Disturb On
    By sctiger in forum Samsung Galaxy S6
    Last Post: 11-25-2015, 04:35 AM
  3. How do I transfer contacts and texts from my Lumia 1520 to Galaxy S6 Active?
    By AC Question in forum Samsung Galaxy S6 active
    Last Post: 11-25-2015, 01:05 AM
  4. Sprint - Galaxy S6 and Note5, how does the RF/Antenna compare on these two?
    Last Post: 11-25-2015, 12:58 AM
  5. Replies: 2
    Last Post: 11-25-2015, 12:19 AM
