Can I get some help finding a folder?
ldawn821
Help finding a folder
I tapped and held down on a folder containing downloaded apps but did not drag it to delete and now the folder is gone. I cannot find it anywhere. Where did the folder go and can I get it back?
Javier P
Ambassador
Feb 21, 2014
19,480
3
Re: Help finding a folder
Hi, welcome to the forums! Give us more details about your problem. Which phone do you have? Where did you do that tap & hold on the folder? Can't you find it using the search feature in a file explorer?
Nanran21
