1. AC Question's Avatar
    My phone wont stop showing the little loading icon to power off. it says "Shutting down..." but it has been like 30 minutes. I cannot take out the battery because it is the hydro, so i would have to unscrew the back cover off.
    11-27-2015 12:55 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! You can usually force a shutdown by pressing and holding Power for 15-20 seconds. If that doesn't work, try holding Power and Vol Down at the same time for that duration.
    11-27-2015 01:55 AM
  3. Unicorn Lover's Avatar
    I cant turn on my Kyocera hydro icon without pulling the battery and putting it back in. Whats wrong with it?
    05-09-2018 05:44 PM
  1. Emails sent from samsung phone and tablets appear unreadable
    Last Post: 08-31-2016, 12:20 AM
  2. Replies: 2
    Last Post: 11-27-2015, 01:53 PM
  3. Replies: 1
    Last Post: 11-27-2015, 02:02 AM
  4. how to uninstall unwanted applications
    By Chandrasekara raja in forum General Help and How To
    Last Post: 11-27-2015, 12:06 AM
  5. I synced my s calander
    Last Post: 11-26-2015, 11:53 PM
