1. AC Question's Avatar
    When I open a app folder (like the Google folder in the main screen)
    The folder has a transparent background. It's very annoying. How can I disable transparency? Solid black color?
    11-28-2015 06:19 AM
  2. Javier P's Avatar
    Hi, welcome to the forums! Which device do you have? With most phones you'll need to install a custom launcher to change that.
    11-28-2015 09:20 AM
  3. a8a8's Avatar
    I have HTC desire 620G. Its default launcher and S launcher have folder transparency.
    11-28-2015 10:17 AM
  1. What apps can I disable?
    By AC Question in forum Android Apps
    Last Post: 11-28-2015, 02:31 AM
  2. Transparent portrait & landscape kickstand case?
    By recDNA in forum Samsung Galaxy Note 5
    Last Post: 11-27-2015, 01:48 PM
  3. How do I make a folder under gallery on my Moto E?
    By AC Question in forum Moto E (2014)
    Last Post: 11-27-2015, 10:22 AM
  4. From Win7 I can see folders but don't see any files?
    Last Post: 11-27-2015, 09:34 AM
  5. Can I get some help finding a folder?
    By ldawn821 in forum General Help and How To
    Last Post: 11-26-2015, 01:25 PM
