1. AC Question's Avatar
    my phone has Attention kfx7-67 virus found. How do I know if it is real?
    11-28-2015 10:35 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Is it a browser popup, or is a legitimate antivirus app on the phone actually finding this?
    11-28-2015 05:06 PM
  3. Maike Van Bergen's Avatar
    I have an pop up with the virus and I can't use my internetpages anymore
    What should I do?
    12-06-2015 04:03 AM
  4. treetopsranch's Avatar
    Your anti-virus program didn't quarantine it?
    12-06-2015 11:16 AM
  5. jpstooker's Avatar
    I have the same popup on my note4. how to get it away? I can install a anti virus programm. but i use 360 security already. Can someone help me?
    12-23-2015 10:18 AM
  6. jpstooker's Avatar
    is there somebody to give us an answer? on this question?
    12-23-2015 10:20 AM
  7. treetopsranch's Avatar
    Doing a quick Google search on that virus turns up some others that have it but no real solution.
    12-23-2015 03:31 PM
  8. belodion's Avatar
    Well, try clearing Cache and Data for your browser.
    If no go, Force Stop, Clear Cache, Clear Data and Uninstall whatever app has spawned the pop-up.
    If no go, Factory Reset.
    If no go, reflash the entire OS.
    Importantly, report anything suspicious to Google.
    https://support.google.com/webmaster...er/93713?hl=en
    Laura Knotek likes this.
    12-23-2015 03:53 PM
  9. Ryan Newby's Avatar
    Sorry for the inconvenience.I was getting pop ups about the kfx-67 virus and looking for a solution. I didn't realize that I left a message let alone an empty on.
    05-08-2016 02:06 AM
  10. belodion's Avatar
    Welcome as a new member.
    Is your problem fixed?
    05-08-2016 04:59 AM
  11. Tonyd19678's Avatar
    No
    05-24-2017 12:59 AM
  12. Tonyd19678's Avatar
    How do you fix it
    05-24-2017 01:01 AM
  13. belodion's Avatar
    How do you fix it
    Welcome.
    If nothing suggested above works, I'm out of ideas.
    05-24-2017 06:42 AM
  1. How to remove FRP lock from my Root Samsung SM-A800F?
    Last Post: 04-21-2016, 10:29 AM
  2. Replies: 3
    Last Post: 11-29-2015, 12:36 PM
  3. Do I need to fully charge my Samsung Tab S2 before I start using it?
    By HelenKrijt in forum Samsung Galaxy Tab S2
    Last Post: 11-28-2015, 11:57 AM
  4. Has anyone tried the Mozilla app for android yet. If so what do you think?
    Last Post: 11-28-2015, 10:17 AM
