A
AC Question
Odin on PC will not open
I downloaded both Odin 3.09 and 3.07 on my pc running windows 7
I disabled the anti-virus, but every time I click on the Odin3 v3.09.exe file a dialogue box comes up with: "Odin3.ini and some Korean writing" and when i press ok, a border appears for less than a second and nothing opens.
I'm completely stuck, i've tried on my other pc too and the exact same thing happened.
I read of so many problems with Odin, but there's only one thred about this happening in 2011 to someone and no one resolved his Odin problem.
Any suggestion on what i can do to make it work on my pc?
Thank you
Thank you
