1. AC Question's Avatar
    my modem was working fine but I got a new computer it worked fine for a while but now shows not in range on my ph and computer
    11-30-2015 12:32 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Do you mean your router? Is it a combination modem/router?
    Try rebooting the router by unplugging its power for 10 seconds, then plugging it back in. See this guide for other ideas: http://forums.androidcentral.com/amb...-problems.html
    Laura Knotek likes this.
    11-30-2015 12:43 PM
  3. arunverma198's Avatar
    try to reset your router.
    11-30-2015 01:16 PM
  1. How do I stream from my Note 5 to smart tv without wifi?
    By AC Question in forum Samsung Galaxy Note 5
    Last Post: 11-30-2015, 05:52 PM
  2. Replies: 2
    Last Post: 11-30-2015, 01:10 PM
  3. Replies: 2
    Last Post: 11-30-2015, 12:56 PM
  4. Replies: 4
    Last Post: 11-30-2015, 08:26 AM
  5. Replies: 1
    Last Post: 11-30-2015, 03:43 AM
