1. AC Question's Avatar
    The app engages even when I am just a passenger in other vehicles and sends out text messages automatically to anyone that texts me while moving. I need to uninstall it completely and not just disable it.
    12-01-2015 11:42 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! See this document: https://forums.androidcentral.com/e?...token=ozp84OsC
    "Simply press the green steering wheel when DriveMode is activated and it will turn off until your next trip."
    12-02-2015 07:19 PM
  3. Seahwolfe's Avatar
    I want it gone completely. Not just turned off.
    12-03-2015 01:03 AM
  4. B. Diddy's Avatar
    Was it preinstalled on the phone, or did you choose to install it? If it was preinstalled, you probably can't uninstall it unless you root the phone.
    12-03-2015 10:40 AM
  1. Replies: 2
    Last Post: 02-09-2017, 03:48 PM
  2. Replies: 4
    Last Post: 12-03-2015, 12:05 PM
  3. What happens if i clear cache's on my samsung tablet
    Last Post: 12-02-2015, 06:44 AM
